Pouring Diesel Fuel
Old 01-22-2005, 01:09 PM
Desert Diesel's Avatar
Arrow Pouring Diesel Fuel
I'm so frustrated I could cry.
I'm supposed to be on my way outta town and my wifey calls my attention to a fluid leak under the engine.
Turns out to be diesel fuel and it's pouring.
It's running down the block, onto the starter and then dripping off the positive battery cable.
I'm guessing the lift pump?
If anyone wants to help, I've got my cell on...
760-608-3409
I"m borrowing a truck to go pickup my free D60 in Palmdale, but it'll still be broken when I get back.
--Phillip
Old 01-22-2005, 02:25 PM
DPG
DPG's Avatar
Desert Diesel, I've never heard of a bad LP leaking fuel, just low pressure. I'd be looking at connections first. Hopefully, some of the more knowledgeable guys will chime in here.
Good Luck! Keep us posted on what you find out.
DeWain
Old 01-22-2005, 02:53 PM
Smokee's Avatar
Rubber fuel hoses
Old 01-22-2005, 04:47 PM
Geico266's Avatar
Not the LP.
Since your wife found the leak make her fix it!
Old 01-22-2005, 06:17 PM
infidel's Avatar
Originally posted by Smokee
Rubber fuel hoses
ditto. When the hose on my 3500 went it did it all at once, I lost 35 gallons of fuel in 50 miles. Barely made it home.
Old 01-22-2005, 07:20 PM
dzpoorjr's Avatar
Originally posted by Geico266
Not the LP.
Yeah like Geico said-she saw it and should have to fix it! Thats the way of the west!
Old 01-22-2005, 10:42 PM
That's for the positive news...
I'll let you guys know in the AM.
Old 01-23-2005, 02:58 PM
Ok, so here we are...
I pulled the starter and I'm pretty sure I found the leak.
It seems to be a sensor on the bottom side of the LP, on the bowl.
I assume that's what I'm looking at right?
Is there anyway to repair that?
Old 01-23-2005, 10:04 PM
No reply yet???
Hmm, if I can't repair the existing pump, what would your recomendation be for aleviating the problem? Aftermarket replacement pump?
Old 01-23-2005, 11:27 PM
2500CTD's Avatar
dunno of a sensor, just the outlet to the VP44. the WIF sensor is on the side. You do have a fuel filter with the black top? Dunno if the matters but mine does and really only remember seeing a banjo fitting on the bottom. If so, maybe some how loosened up? hope this is some kind of help. keep us posted
Old 01-23-2005, 11:31 PM
AggieJustin's Avatar
That's not a sensor on the bottom of the LP, that's the power connection for the LP motor. If you have fuel leaking from this plug, then that means that the seal around the pump shaft must have started leaking, letting fuel get to the motor internals where it can drain down the wiring.
Are you sure that it's coming from the wiring? Or is it coming from one of the banjos on the side and pooling on the connection before it drips off?
Old 01-23-2005, 11:48 PM
The banjos are dry as a bone. It's definately leaking from the two terminal connector on the bottom.
It's running down there onto the wiring to the low-point (where it begins to curve back up) then it runs off the wire and onto the starter where it basically soaks it.
Also, I'm not talking about a simple drip, I mean it looked like a rain storm while the truck was running.
Old 01-23-2005, 11:49 PM
2500CTD's Avatar
oops read it wrong was thinking of the fuel filter. I actually thought the pump was fuel cooled?
The sides of the LP (The bowl looking part) are dry and still dust covered.
Old 01-24-2005, 12:13 AM
Hemi Cat's Avatar
WOW!!! That's 1.43 MPG's
I had to repair my return hose a couple times on the road too but I was lucky to catch it shortly after it started leaking, then I decided to replace the complete hose. $2. worth of hose aint worth loosing a tank of fuel.
Quick Reply: Pouring Diesel Fuel
