please help wont start
My truck wont start or actually it started but shut off right away a friend told me to put a salamander heater under it and I did and nothing yet. He says its ice in the fuel line could this be it. I didnt use any antigel or anything cause Ive been following the manual. I have the 04 1/2 dodge cummins. I was plowing till late last night and it was plugged in all night long. Any help or suggestion would be greatly appreciated. I live in jersey so it is cold now. I have to get to work.
Thanks Don
Thanks Don
More info , how cold is it , do you know what kind of fuel your getting #1 ,#2 or a blend it should say on the pump, if it is gelded fuel than put about 1 gal. for every 20 in tank of keroseen , as for heat to warm up fuel and lines any form of uncontrold heat could cause many other problums, to heat up lines I would go to a hardware or pluming supply and get heat tape and start from the injector pump and as far as you can get easy access to and plug it in for a few hours . good luck ,
It should work its way through the tank but I dont think it would make it though the fuel lines, as for causing problums make sure that you donot mix it more than 10% I have been hearing about this for about 20+ yrs. and seen it talked about on this site also. about heating the lines like I said heat tape or auto parts store a magnetic heater maybe $15 to 30 you will find many uses for these later , what about the fuel in the truck now ? what mix or not. I will be here on the site for a while.
___________________________________
94 2500 4x4 auto cummins
DmaxEter
43
08-28-2012 07:45 AM
JG_DIESEL59
05-08-2010 11:22 AM
newguy2005
14
08-08-2006 08:15 AM
