Please Help-Excessive Blowby
I just purchased a 2004 Dodge Cummins 3500 Dually. I drove away to find that in 200 miles I used, or rather dumped out my blowby tube, 2 quarts of oil. When I stop, blowby exhaust fills the air. I am to drive this truck through Canada in a couple of days by myself, what is wrong with it??
Krystal
Krystal
What does your oil level look like? How does the oil feel?
Sometimes, when you have a lot of oil coming out like that, it could mean an injector has gotten stuck open, flooding the crankcase with oil. Hopefully, this is not the case, and the breather is just clogged.
Well the oil was really nasty, and thick, felt kindof greasy. I had it changed, I only use Delo 400 LE 15-40. I drove a total of 355 miles to get where I am. Just bought the truck two days ago. Now checking the oil, it doesnt stick to the dipstick like it should. I didnt feel it, was in a hurry to get inside after a long day. But it looked very thin (because it didnt stick to the dipstick). I have a warranty don't know if it will cover it, but I guess I am taking it to dodge tomorrow. Before I drive home to Alaska.
Oh, and it has a Bully Dog Cold Air Intake Filter System on it.
If this is the case, I would not drive it, I would have it towed to the shop.
Sorry.
I could always be wrong. Hope I am.
Thank You for helping me, I wanted some kind of Idea on what was wrong. I know that it shouldn't blow out that much oil, I can see it dripping out of the tube at an idle. Also the whole underside is covered in oil. I am at my brother's apartment, so will look at it all in the morning. I hope actually that it is something simple, and easy to fix; Rather than something unfixable in short amount of time.. I have to drive this thing 2500 miles in the middle of nowhere.
oh, and I don't know yet, but my guess is that it is low, 'cause it is all coming out of the blowby, I mean visably, oil leaking/drippping out of the blowby tube with visable exhaust that fills the air around the rig. Not good, especially when I will be spending the next 24/7 inside of this truck on the way home. Day And Night..
No problem, good luck. If it is injectors, don't drive it.
If you have to have them fixed on your dime, the best name in injector repair right now is Don M at F1 Deisel. You can't send them directly to him, but he has dealers.
A little trick I use to see if I have fuel dilution in oil is to get a brown paper bag and put a little on it. Fuel will "Wick" out/across, on to the paper bag faster then the oil. Hotter the oil, the harder it is to tell on the bag. If you haven't done this before, it can be hard to diagnose what your looking at
I know this is a few days later but -
It sounds like the previous owner was running veg oil instead of diesel (sticky oil) and it could be a stuck compression ring.
My rig ran fine when it stuck an oil ring. It just blew lots of smoke out the pipe and ate oil like a fiend !
Tons O' fun !
Tons O' fun !
Thank You everybody! I took the truck to Tacoma Dodge. They determined the truck had #5 dead hole, and 3-4 barely firing. I somehow got lucky, and the dealer gave my money back. I was able to purchase a truck from Dave Smith Motors, they are the most wonderful people, and excellent service. Ended up with a 2005 Cummins Turbo Diesel, 3500 Big Horn Edition, but has a short bed and single rear axle. We will see how I like it. Truck also has an ATS Aurora Turbo, Banks High Ram, and a K&N Air Filtration System, as well as a 6" MBRP Exhaust system from the Turbo Back. It is a really nice rig, and should pull the horse trailer through Canada with no Problems.
