p-ecu, What does this mean for codes?
My buddy's 02 5-speed had a hard time starting; just cranked over quite a while with no start, then finally started. I think he just needs to hop it up so he has a reason to have it broken The only code is p-ecu. I don't know much about these 'puter pickups thanks, bruce
I just did a search and found this is a normal code to get. Any other ideas? I suppose a weak lift pump could give this trouble; a bad inj. pump should give codes tho, right?
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
