P-0236
Old 03-12-2004 | 05:15 PM
Amish hauler's Avatar
P-0236
Just P-0236. ( MAP sensor Performance/Rationality)
No check engine light.
Can clear the code and check codes with odometer once and nothing. Don't start engine and check again and it comes back.
Do I just replace the MAP sensor? Is that how you fix Performance/Rationality? I feel it has a good connection.
Old 03-16-2004 | 11:34 AM
DODGE4X4's Avatar
Well you could go by Dodge and see what they say. I know my dealer wouldn't charge me to hook up there computer to my truck.
Old 03-18-2004 | 07:13 PM
I asked them. They said because it was out of warranty(215000miles) they would have to charge me. (darn yankees)
Old 03-18-2004 | 07:22 PM
dsldan's Avatar
I think I would try cleaning it first and if that dosent work then try a replacement. have a scan tool if you want to stop and use it to clear the codes.
Old 03-18-2004 | 08:23 PM
Dsldan,
When you say clean it do you mean the plug and connection or do you mean internally? Also how and with what if you mean internally? The conection seems clean and fine.
Old 03-18-2004 | 09:14 PM
dsldan's Avatar
I ment internally, unplug it and unscrew it then clean it with carb cleaner and reinstal.
Old 03-21-2004 | 12:25 AM
DODGE4X4's Avatar
What size socket does the MAP take ?? Just so I know before I do it
Old 03-21-2004 | 02:34 AM
dodgediesel4x4's Avatar
It should be a 1 1/4" but you need a deep socket.
rattlebox01
12-01-2009 10:24 AM
screamin01
08-05-2008 02:07 AM
griffy
02-17-2008 01:04 PM
loid mongol
08-21-2006 04:18 PM
Charlie8301
06-11-2005 10:29 PM
