overdrive shifts in and out all the time???
I'm not sue where to start. while driving It will go into OD but then shift right back out again. Then in again, then out. It keeps doing this.
Also , I have seen mal adjusted / bad break switches do that , you can take your foot and put light pressure under the break peddle , lifting it slightly , if it stays in Lock Up , that's your problem .
Yep, TPS. Take a look in the sticky at the top of the 1st gen board for info on adjusting the TPS (try that first, it's free) as well as a few low-buck alternatives to a $200 TPS.
DezertBum
11-18-2009 04:32 PM
jcamron
09-23-2009 07:30 PM
samahi72
09-12-2006 07:47 PM
bigbaddiesel
11-23-2002 02:33 PM
