Oil Leak @ turbo return line to block.
hey all....it isnt that seriors...it seems to be a leak at the above mentioned spot....where the return line goes to the block not at the top of the line only at the bottom where it goes into the block...
best way to go about fixing it....is what i am looking for....are there any seals that need to be replace...
it is a small leak but it drips down on the block and runs back to the rear....where it pools and drips down....
thanks
NCA
thanks
NCA
thanks
NCA
thanks
NCA
Thought mine was leaking too...
But on the other hand, I have no idea how to fix it.
oil drain tube bolts to the turbo and there is a gasket between the flange of the drain tube and the turbo then the metal drain tube goes into a rubber hose and into the block
anyone have an idea.
NCA
1 Post
mine hose clamps holding it to the peice that comes out of the block. had the same problem with the dump truck with an n14 and the tube out of the block was loose
there is a pipe (in the block which is most likely pressed into the block ) if you want to call it that the hose clamps on to it
*drain tube,rubberhose,pipe in block
thanks guys....it seems there is NO hose clamp on it.....and the hose is pulled up a bit....
exactly what i needed...any guesses as to the Dia. of the hose to fit clamp accordingly???
NCA
NCA
tacohat
08-07-2013 06:23 PM
pcgym
08-14-2010 03:53 PM
ctd4stan
05-18-2009 02:56 PM
banks twinram
01-04-2005 04:27 PM
