oil coming out of exhaust at muffler
massive amount of oil coming out of exhaust where muffler attaches to catalytic converter, when motor is running. spewing it all over under side of vehicle. no oil leaking anywhere at motor, or from catalytic converter forward.just happened today massive amount of smoke coming out of exhaust pipe at rear of vehicle. motor is an '01 24 valve cummins 60,000 miles, never had any problems
Your blowing oil past the seal on the exhaust side. Take the intercooler elbow off of the turbo, and see if the compressor side has blown its seal too. There will be oil in the elbow and all in the intercooler.
Yup, that's really the only thing it can be. Besides, you can always trust a Fred! Hopefully you are still under warranty because you're probably going to need a new catalytic converter too.
It is a resonator, not required by any EPA regulations, just there for customer satisfaction, reduces the droan in the exhaust.
phox
Originally Posted by phox_mulder
2001's didn't have cats.
It is a resonator, not required by any EPA regulations, just there for customer satisfaction, reduces the droan in the exhaust.phox
Duh...yea, I read that somewhere. Are they essentially a second muffler? I've also heard about the "drone" and I'm wondering if it's also what some refer to as resonance. I've had my exhaust in 3 different configurations in the last 2 months, some that others had complained about drone with. I've heard "growl" when under a load but nothing objectionable. I guess if towing long distance some might call it noisy.
Yup, Drone=Resonance.
Resonator, stubby muffler, named because it removed the offending resonance.
12 valves had cat's, 24 valves didn't need cats due to their burning everything more effenciantly, but they had the same exhaust system, when DC removed the cat the drone appeared, so they put a stubby flow through muffler in where the cat used to be.
phox
phox
glenn9898
10-01-2013 08:42 PM
freight train
02-07-2013 04:02 PM
officer4u
03-09-2009 12:16 PM
commonrail
10-22-2004 07:47 PM
