Odometer quit
Old 07-05-2003 | 12:26 AM
Dodgerammer's Avatar
Odometer quit
I had 174,999 miles on my truck and it just stoped and would not turn over to 175k. Also when I stoped after a long trip my oil pressure gauge just went down and the oil light came on.
Old 07-05-2003 | 09:56 AM
awmasparky's Avatar
Re:Odometer quit
Dodgerammer,<br>There is a test that can be done to test the gauges, I don't recall how it is done. Something like turning the key on while holding the trip meter button. I believe it may give you a fault code. Sorry I don't remember but if you do a search, there are some threads on how to perform. Search long enough and you will probably find someone who has had a like problem.<br>Hope this helps.
Old 07-06-2003 | 06:24 PM
firestorm's Avatar
Re:Odometer quit
I don't know if this will work on the 1st gen. diesels, but you could try it. Hold the trip/odometer button in while turning the key to the 'on' position. The odometer reading should read &quot;CHECK&quot;. Your gauges and warning lights should come on and max-out.This takes a couple of minutes to run. After this is done, turn the key off. Now, turn the key on and off 3 times, ending in the on position. A code number(s) should apear in the odometer. I know this works for the 2nd gen., not sure about the 1st gen.
Diesel Junkie
10-18-2009 02:20 PM
dieselbryan87
05-11-2008 10:12 PM
VADSLRAM
11-29-2005 04:12 PM
signature600
07-06-2005 10:59 AM
