NV5600 swap
Muted User
NV5600 swap
My 96 Dodge 3500 Diesel 4x4 5spd is losing 3rd gear and the syncros... before I commit to buying another NV4500 I wanted to know this...<br><br>Will the NV5600 go into a 96 Dodge truck that had a 4500, without having to change driveshaft lengths or mounts etc? I know I will have to get a new flywheel and clutch. Help!
Re:NV5600 swap
The driveshaft will need to be shortened, as the NV5600 is quite a bit longer than the NV4500. There is a complete transmission and installation kit available for this, and I had a friend buy one and bring it to my shop to install. It is pretty easy, and the driveshaft is not that expensive to have shortened at a speciality shop. I will look up the kit supplier and get it posted so you can check with them.<br><br>My experience is that you are better off to rebuild the NV4500 and add an overdrive. I suspect it will be about a thousand dollars less expensive than the transmission swap, and you get 10 forward gears instead of 6.
Muted User
Re:NV5600 swap
Okay. Thanks. I was going to buy a used 5600 for about $800 from a salavage yard nearby and try to make it work.. but rebuilding the 4500 is prolly the best idea....how much foe the overdrive? Does it go on after the transfercase?
Re:NV5600 swap
RCW are you talking about the Gear Vender or something else to give you an over drive? Would love one on mine when I decide to fly instead of pull.<br><br>Thanks
Re:NV5600 swap
nv5600 might be cheaper in the long run, saturn overdrives are up around 800, they go on after the tcase and also require a new driveshaft, compare the two and see whats cheaper<br><br>if ur goin to go with the saturn, give advanceadapters a call
getblown5.9
01-27-2007 01:36 AM
LooseBoltsRob
01-15-2007 07:09 PM
Diesel-Dan
0
07-26-2004 03:27 PM
