No truck,fuel line- an,metric,npt
Removed banjo's a long time ago and have been using 3/8" inlet/outlet carter fuel pumps with npt brass 90 deg fittings. I now got a pump that's metric (12mm x 1.50) inlet and outlets.
Where can I find a metric male thread to a 3/8" barb 90 deg fitting?
Or other suggestions? I am not want to go to high $$$ aero stuff.
Is 12mm the same as -12an or what? I am confused.
If I have to I will send back metric thread pump and get the npt universal pump?
12 AN and 12mm are not the same. 12 AN is not a thread size. The 12 means 12/16 which is 3/4 = ID of AN fitting. AN and 37* JIC hydraulic fittings are compatible eg. #12 JIC = 12 AN. None of this stuff is metric.
You will have to get some specialty adaptors to make this work. Earl's, Aeroquip and other AN fitting manufacturers may be able to help but I would go to a good hydraulics shop and have them order the adaptors you need if they don't stock them. A good shop will be able to take care of you.
walexa
09-22-2005 07:34 PM
Parvenu
10-18-2003 03:10 PM
