Need to reset 0234 code - how?
Originally Posted by SSV1761982
Disconnected batteries and the 1693 went away but the 0234 stays. What is the trick?
On my truck, it took about six start/drive/shutoff cycles before it would clear, once the problem went away. Disconnecting the batteries would not clear it on mine either.
Paul
How did I set the code? Good question.
I don't know how or when it got set. I don't drive it hard most of the time. Everynow and the I do "blow the carbon out of it". I noticed a while ago it seems to surge in 2nd and 3rd sometimes. Seems to be kind of flat in the other gears. I do have a 4" exhaust on it if that makes any difference. The truck only has 75k on it.
Thanks,
Dave
Thanks,
Dave
I had the same code on my 2002 HO. I fiddled with the harness that plugs into the MAP sensor and by the time I could get into the dealer the code had reset it self and the dealer could find nothing.
A question for the board -- If the MAP connection is bad will this set the code even though the boost is not high?
Thanks,
Jack
Thanks,
Jack
fireman0977
09-24-2008 10:32 PM
SSV1761982
01-29-2006 03:32 PM
