need help with fueling box
Where does it plug into the pump. Its a bully dog box and it has three plugin spots. friend just called me and is putting it on as I type but can't seem to find the plugs.
Thanks
DM01
Thanks
DM01
Re:need help with fueling box
I don't know bout the bully dog, but on my edge, it plugs into the MAP sensor (located to the right of the plug you pull out of the block to hook a boost gauge to). It also plugs into the data port sensor which is below the fuel filter housing and right next to the engine block. The only third connection I have is to my injector pump. And I use a blue chip cover for that. Now, this is on an 01 truck. I don't know if the connection points have changed from year to year or what. But this is how my Comp hooks up.
cgmorgan06
11-15-2007 03:31 PM
sledneck1
09-19-2007 10:00 AM
blackdiesel
18
03-31-2006 12:40 AM
doug
49
04-20-2004 08:45 AM
BLUTIC
12-16-2003 09:00 PM
