Need a Headgasket Fix
I've lost two head gaskets in less than 10k miles :'( on my 96 5 speed, running TST #10, stock injectors, K&N air filter, 16CM HY35 turbo, and open exhaust. I remember reading about a fix for high cylinder pressure head gasket woes, but now that I need it I can't find it. I am pulling a 53' trailer delivering boats and see arox 34lbs of boost when the old girl is working the hills.
Re:Need a Headgasket Fix
That boost & temps are on the low side of causing any trouble.<br>The only thing I can suggest is doing it again. <br>Try www.buddhapower.net for the head gaskets, also tell him about your 2 in a row.<br> Danny
Yes the warp/defect checks have been done. How about some technical/how to info on o-ringing the head, or a source for the info.<br><br>Thanks <br><br>Dave
From looking at your signature there is no reason for the head gaskets to be letting loose. If the head and the block are stright, I would have to say that you reused the head bolts. These bolts are strech to yeild and should never be reused. As far as o-ringing goes also all performance head shops will be able to o-ring, keep in mind they will need a new head gasket to do this right. Good luck and happy ramming.
Send J.R. Adkins a PM, he just had it done on his and posted the pics in the Member Photos section too.
This link should take you to his pics.
http://www.dodge-diesel.org/yabbse/g...s.php?album=94
8)thanks for the help. I am waiting for a new head gasket seems my local Cummins shop ran out and they are back ordered. The new head bolts are here now. Once all the parts are in and the results are known I'll post a follow up.
Dean Snow
10-27-2010 07:13 PM
Dufrain
01-06-2005 12:03 AM
