nails on the chalk board
Old 03-31-2006 | 04:17 PM
singleturnout's Avatar
Exclamation nails on the chalk board
i tightened my steering box up last week still wanders so i know i have to replace my trac bar but now iam getting a nails on the chalk board sound out of the front left tire only when iam at slow speeds could this be the wheel bearings i have no way to jack it up what are some symtoms if your wheel bearings are going and how much and were can i get new ones
thanks aaron
Old 03-31-2006 | 06:41 PM
no onr,anybodt out here
Old 03-31-2006 | 08:08 PM
infidel's Avatar
Sort of hard to help you if you can't jack it up.
You need to get the tire off the ground and give the wheel a spin listening for where the problem is.
Old 03-31-2006 | 08:16 PM
ramruff's Avatar
Aweful sounds you don't wanna hear !
The squeakers on the front brake pads that tell you when its time to change the pads before you ruin the rotors. Also front U-joints on a 4x4 will squeak when they get dry (out of grease) & you know you gotta change them soon.
Old 03-31-2006 | 08:25 PM
oscaroc's Avatar
You can use the jack that comes with your truck to get it off the ground. That is if there is still one in there.
Old 04-01-2006 | 12:12 AM
jaconst's Avatar
I have had that same sound but it only seems to come when I its wet out it did it tonight really bad but after driving awhile it pretty much stopped only does it when I am driving and stops when I stop. slower speeds it sound like the sound made by an amusement ride, like a merry go round, that is driven by friction with a tire as the drive, if that makes sense.
Old 04-01-2006 | 03:37 AM
kerryneb's Avatar
i've never heard of a serpentine belt slipping, but if the noise is only when you turn the steering wheel (put a load on the power steering pump), that might be the problem. My other thought is alternator, water pump, power steering pump, or idler bearing...loosen belt and spin bearings by hand to feel/listen for a dry one.
Old 04-01-2006 | 10:34 AM
JKM's Avatar
JKM
Power steering pump is gear driven on a CTD.
Old 04-01-2006 | 01:41 PM
Its Not Coming From The Engine Compartment But From The Left Front Wheel Its Going To The Shop On Monday Hope Its Not The Wheel Bearing Assembly Hopefully Its The Front U Joints Or The Brake Pads
JACONST THATS EXACTLY WHAT IT SOUNDS LIKE
Old 04-01-2006 | 01:59 PM
gman07's Avatar
I had a rock get stuck in the splash guard on the front right brake and it made a similar noise. Hope you get it fixed.
Old 04-01-2006 | 10:20 PM
jaconst's Avatar
Im thinking its the center bearing for the drive shaft or midship bearing I'm going to post it was bad this morning and went away when it got warm out
tmacie
03-06-2006 03:49 PM
fearthedeere
03-20-2005 07:38 PM
04ctd
03-06-2005 08:21 PM
Lil Mule
08-05-2004 07:06 PM
