major no power--owned 3 days--help
just bought my first cummins 3 days ago (waited 4 year to get) 98' 4x4 (24 valve--auto) ww/63k miles and nicely kept..the truck is a dog..im merging onto highways at 40 mph..ive driven my uncles 94' 12 valve and it will walk circles around this..today i changed the air filter, fuel filter and bought a new up pump direct from cummins cause i hear this is common..no help..also, truck seems to "miss" when cruising and surges at idle..it shut off this morning at a light in drive but started right back up, the temps are around 20-25 deg. here however i filled tank and added anti-gel..also ive plugged it in all night...PLEASE help, ive got to get it right, i took off work to fix it..could the turbo not be working, i dont hear it?? also my tach needle is jumping back and forth to zero
Administrator / Scooter Bum
Re:major no power--owned 3 days--help
Here's a little info from the Tech Facts section at the top of the page. There's a gold mine's worth of stuff in there. <br><br>How to change a Crank Position Sensor.<br>https://www.dieseltruckresource.com/...p;onlynewfaq=1<br><br>Hope this helps.<br>Ed
[quote author=barracuda link=board=13;threadid=10063;start=0#96716 date=1043598331]<br> thanks again...cps did the trick..it was a bear to get out though!<br>[/quote]<br>Welcome to the site barracuda,<br> Glad you got the problem fixed! The members here are always willing to help out with info and more. I have learned a great deal from them. ;D
Baracuda Time for the bombing bug to bite might I suggest a set of gauges, EZ box, stage 2 injectors,scotty 2, 4" exhaust, DTT tranny.
boaterman
10-15-2008 10:44 AM
allenc
07-15-2007 06:36 PM
