Major Help needed in Alexandria, LA
Hubby stuck on the side of interstate 49. Trailer blew a tire and destroyed the rim. He has no spare. He needs a 6 lug rim/tire for a 5200lb axle. Or transportation to one. aim: crazymopargirl
Sorry been looking for a trailer place open today. no luck, Its a 28' loaded car hauler. Tire blew, destroyed the rim, ruined the U-bolts, so I need new U-bolts rim/tire, and hopefully not a spring as well.
trailer tires sukk!!! If you are pulling any distance at all from where you are fubar'ed I would highly recommend replacing the tire on the axle that didn't blow also. Once one goes out you put quite a shock on the other. I blew out a 2 yr old low mile carlisle in vegas last month so I'm shopping for a whole set now. They do make a 225/75/15 in an "E" rating so you may want to pursue that angle. I'm hoping to upgrade to 16" wheels on my 5200lb 6 lug axles. Seems that they last a bit longer in those sizes from my research on the subject.
No prob. It looks like the valve stem split as I was driving. So it leaked went flat and then chewed the rim. I always make a lap and check all the tires each time I stop. So it went flat after I started driving ~3hrs. Hoping the trailer place has what I need Monday morning.
Deezzle
03-01-2011 07:46 PM
chaikwa
11-16-2006 10:37 PM
dieselminded
20
10-15-2004 10:44 AM
benderbrew
08-12-2003 11:33 AM
