Loud SQUEAL when engine stops???
I have a 2001 dodge 2500 cummins diesel pickup. Engine runs fine, BUT ... when I turn the engine OFF, I hear a short, but loud, sharp "squeal" sound. It almost sounds like a "sucking" sound, but it's closer to a belt squeal. It does NOT make this sound when starting the engine or when running. It makes this sound almost everytime I turn the ignition off. The transmission is in PARK. It makes the same sound whether or not the air conditioning is on.
I assume this is not normal. I bought the truck used a few months ago. I can't really remember if it always made this sound or not.
I don't know much about diesels and I'm NOT a mechanic. I'd appreciate any advice you can give me.
Thanks,
- Simon
Thanks,
- Simon
I'm pretty sure what you are referring to is the engine shutting down. I believe this is due to the high compression ratios that our engines run and is pretty normal. Basically when it stops, it stops. Mine does that too.
Mine does it too, especially if the A/C is on...in fact I think there was something in the manual which said to not be alarmed about the squeak. I think I read here that, like waldersha says the engine stops pretty quick, and some of the accessories will keep turning causing a squeak.
Don't worry, it is nothing, just the belt slipping when the engine decides to come to a 'scretching' (don't mind the pun) halt. My '99 did it and my '02 does it when it is hot and the belt can slip a little. Just act like it is the car next to you when you shut down at Sonic and everyone looks at you like your truck is a POS. They'd never understand the 'high compression' explanation so we just let them think that. Good Day....
Originally Posted by SimonRV
Thanks to all who responded so quickly to my post about the engine squeal. This is my first diesel truck ... I've got a lot to learn.
- Simon
- Simon
by the way, welcome here, i think you'll like it here, i'm personally addicted but be careful, this site will put lots of ideas in your head. i mean look at me, i started out with a bone stock truck, and was fine with that, but then i found this site, and i found the classifieds on this site and so on and so forth, i mean just look at my signature, and that's just the beginning!
oh also, don't forget to fill out your signature so we can see what you have at a glance. like mine below.
Originally Posted by H2SRDMB
mine quit chirping... should i beware somthing is wrong?
I am so used to it now, that today when I shut the truck of it DIDNT squeal, I popped the hood because I thought something was wrong!!
Started it back up then shut it off it squealed so I shut the hood and went into the house with a smile on my face.
doomgaze
04-26-2006 05:28 AM
