locked out????
Old 01-05-2005 | 12:02 PM
quantrill88's Avatar
locked out????
Ive got what I hope is a simple problem here guys. When I went to leave for work this morning I hit the unlock button on the remote and went to open my door, came to find out that it unlocked every door BUT the drivers.
No matter what I do I cant unlock it, key wont turn in the lock, remote wont work, auto locks wont open it, neither will pulling up on the ****. The only way to open the door is to pull up on the handle, it stays locked as soon as you close it however.
any ideas??? Its really annoying to have to climb over the passengers seat to open my door. Luckily I have a remote, otherwise Id be screwed, since dodge only put one actual lock on the truck
Thanks for any help
Jeff
Old 01-05-2005 | 12:23 PM
natstayl's Avatar
I think if you remove the door panel, you'll discover the problem. Probably the clip that holds the locking pin in place has came loose. The loose rod probably fell and wedged between the key lock cam and part of the door.
Old 01-05-2005 | 12:32 PM
I just got off the phone w/ the dealer and he said the same thing you did nat. Too bad they claim they cant fit me in till late tom .
How much of a pain is it to remove these door panels? Ive done it on my 2000 but not on this one yet. Do you have to buy that clip?
thanks again
Jeff
Old 01-05-2005 | 01:53 PM
natstayl's Avatar
No you don't have to replace the clip (unless it's broken). You should be able to reclip the clip and be on your way. But I think I would tie-wrap (or bread tie wrap) something around that clip to keep it from happening again.
It's not hard to remove the door panel, all the screws are visible then you just slide it up toward the top of the window, it has hooks molded into the back side of the door panel that fits slots in the door.
Nat
Old 01-05-2005 | 04:09 PM
mikmaze's Avatar
don't forget the big torx screw in the door handle inside, funny angle to get at but if you don't take it out that door aint budgin. easy on the screw gun or it may strip real easy
Old 01-05-2005 | 06:28 PM
Crimedog's Avatar
I'd just let the dealer do it since its most likely under warranty. A buddy of mine just broke a little chunk off of his sister's door panel trying to get it off. This way if it cracks or brakes its on their dime.
Old 01-06-2005 | 01:21 AM
thumper 549's Avatar
Is it cold there like frozzzzzen?
Old 01-06-2005 | 08:09 AM
J BODY's Avatar
I've replaced two door latches for that very same problem. Something internal in the lock mechansim bound up. The new DR body door panels are much more user friendly than the BR/BE panels.
Old 01-06-2005 | 08:50 AM
J Body, thats exactly what it turned out to be. Dealer ordered it and said it should be here tom. Kinda glad I didnt go and tryn fix it myself.
anyone else have this problem?
THanks again
Jeff
Old 01-06-2005 | 11:44 AM
edwinsmith's Avatar
When I got my 89 the door locks were jammed. It has power door locks and both motors were rusted solid. The door speakers were bad also and it appears the truck had been in a flood. I was able to get one motor working but the other was a goner so I left the motor out. Doors now lock the conventional way. It's odd that it was designed such that there was no slop in the linkage to allow manual operation.
Edwin
BTW, I'm looking for a used right door motor.
fortunate1
06-11-2013 08:54 PM
timcasbolt
21
03-17-2006 08:12 PM
jrs_dodge_diesel
01-27-2005 07:09 PM
katoiler
04-27-2004 01:15 PM
DodgeRamCO42
17
11-23-2003 09:33 PM
Quick Reply: locked out????
