Lift pump runs but no fuel to filter housing
Working on a '00 won't start and found that we have no fuel coming out of the return line off the VP, so took the cap off the filter and pulled the filter and bumped the key lp runs but no fuel.
Is there any fuel in the tank? The gauges lie on these. Next I would check the lift pump. Just because it runs does not mean it pumps fuel. The electrical part of the pump could work, but the pump part might have failed. If the pump will pull a vacume then check for air leaks between the pump and the tank.
same thing happening to my 99....water in fuel light came on, dained and put a new filter.....turned key on 3X, could hear it running, but no fuel to filter...thought I only had to worry about the tranny....is it worth going to a summit pump, some say after market is junk.....help
just get this and be done with it...call Lary I believe DTR members get a better deal then the price advertised....and it supports the site
end thread jack...
http://store.dieseltruckresource.com/19pelipusy.html
end thread jack...
banks twinram
13
12-01-2010 05:41 PM
Tiara3100
13
01-01-2008 03:23 PM
Tiara3100
12-21-2007 02:42 PM
silverdodge04.5
04-20-2007 05:43 PM
