Intermittent rattle/smoke/power loss
Similiar problem to the '03 listed but with intermittent symptoms. The noise seems to come from the drivers side and will usually only lasts for a minute or so. While doing 55 mph you can hear the engine unload and the pedal will be dead unless you floor it and then it drops a gear and runs fine. It is blowing blue/white smole almost constantly but the oil level is still dead center on the stick and does not smell of diesel. It smokes much more on starting. Thoughts?
RHC
08-12-2019 03:32 PM
RJZBYD
03-28-2006 12:26 AM
