Installed Edge Comp, Check Engine Light On
Just finished installing my Edge Comp and now that Check Engine light is on I also show code P0122, What is this code?
I was just out in the garage checking my connections and the engine is stone cold, but the air intake where the ground is connected with the other ground is rather warm, it is the warmest thing in the entire engine compartment and the turck has been sitting all day long, please help
Just went back out to the truck and the Intake was really hot, i disconnected the batteries and i am now going to try to ground the comp to the negative battery terminal
I connected the ground for the comp box to the bolt on the intake that already has the ground on it just like the directions said, so i said heck with it and hooked it up toa different bolt on there intake and that seems to work, but to day i am going to buy some more wire and hook it dirrectly to the ground on the battery
Did you hook the wire to a grid heater stud or an air horn mounting bolt? One of the 4 air horn mounting bolts is where the Comp should grounded.......
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
madbomber
11-15-2004 05:07 AM
