injector issue ??
Old 03-23-2006 | 09:46 AM
kinser5mfan's Avatar
injector issue ??
started to smell raw fuel but there is no leak on the ground i am also haveing fuel loss or excessive use. could this be an injector problem? if so is there a seal or o-ring kit to fix this??
Old 03-24-2006 | 04:43 PM
high country's Avatar
better check the oil level.....is it up? if so you could have a leaking seal in the vp that dumps fuel into the crank case. if not, check the lines at the back of the engine for any dampness, it does not take much of a leak to produce a lot of smell.
Old 03-24-2006 | 06:57 PM
thanks for the info oil is normal level
Old 03-24-2006 | 07:40 PM
HdPower's Avatar
Not to alarm you but mine started out smelling of diesel fuel, ran fine but I too noticed excessive fuel consumption.
For more info go down a couple of threads see "big problems".
dan123dbl
02-13-2015 05:47 PM
75bronco
01-30-2007 08:38 PM
getblown5.9
03-02-2006 01:07 PM
DDysput
05-05-2004 07:44 AM
Quick Reply: injector issue ??
