Injection pump Trouble
Does anyone have any info about the VP44 problems. I have recently been having problems with my truck bucking when at full throttle. I have a fuel pressure gage and it stays above 5 psi. Today my check engine light came on, I pulled a DTC code using my Cummins Quickcheck, it was P1698 "Fuel Pump-ECM." Does this mean my Injection pump is getting ready to Die? What can I do to check it? Any suggestions for troubleshooting?
Originally posted by RamHunter01
How do I do the signature?
Fuel pressure shouldn't drop below 8psi.
Classic symptoms of a lift pump failing.
The P1698 code is (according to the source I use):
P1698 No CCD Messages Received From PCM
Most likely dirty connectors at the PCM.
(cheapest, easiest thing to check first)
The PCM is mounted on the passenger side firewall,
and has 3(?) connectors with many, many wires coming out of it.
phox
tommurray
02-23-2014 10:38 AM
ridlangus123
12-30-2013 08:36 PM
InjuredOften
01-21-2011 05:41 PM
cumminsdriver635
05-04-2005 09:25 PM
