Injection pump? or lift pump? or ecm?
i have a 2002 dodge 2500 ctd and this morning i went out to start it and it started kind of hard but it started. went in the house and it died. went out to start it and the guages and electronics all were going crazy. it started up but after 3 minutes it revved up a couple times and died. I clicked the key and read codes for lift pump, injector pump,over boost,and ecm. ihave quadzilla 120hp module and its unplugged. i hauled a car with truck yesterday and it drove fine on 30hp setting. please help!!!
The number of faults would lead me to suspect a bad connection to the ECM or the Quadzilla was the problem, but it could be that the modules were unplugged with the batteries still connected, and that can blow one or both ECM and PCM.
I would disconnect the battery grounds, turn on the ignition key and lights, and let it set long enough to drain all the capacitors in the truck. Check your connections, and make sure they are dry and coated with dielectric grease.
Then turn off the lights and key, and double check the connection to the camshaft sensor, then reconnect the batteries and cycle the key twice, then start it.
6spd05Dually
03-12-2011 12:19 PM
jrussell
17
09-17-2007 06:38 PM
Ohio Joe
07-12-2004 12:13 PM
