Injection pump help needed...
Well I'm now getting at least 14psi on my fuel pressure gauge after changing the lift pump. I'm only getting this pressure after cycling and bumping the engine. The truck is not running as it died which is why I changed the lift pump to see if that was the problem. What can I do to test the injection pump? The only code I have is 1693. Please help. James
When my vp44 went south I did the turn the key on 3 times thing. I got the 1693 code and I quit. I should have left it on until it finishes. I cycles through 2 tests. A pcm and an ecm or something like that. Before you quit the code look-up make sure its finished reading them
It has been my experience with these trucks that when they don't start it is almost always fuel related. Sorry, but it sounds like your VP has said farewell.
tommurray
02-23-2014 11:38 AM
kawi600
06-03-2008 04:27 PM
OT-OF-Here
27
04-28-2007 06:46 PM
