im stumped.. 04 dodge abs/brake light
so the truck is wigging.. the abs light and brake light flash at me wile i drive.. when i go to stop the speedo stops at 5mp flickers up to ten then slowly bounces back to 0
replaced the vehical speed sensor in the rear diff.. replaced battory checked connections ect.. please help
thanks nate
thanks nate
Double check the connections. I had the positive battery cable that runs from the driver side to passenger side go bad. Mine also would blow up my passenger side battery too though. But I got the same problems you did
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
mr T
02-24-2007 06:42 AM
