I'm getting water inside passenger side of the truck
I got a 97 DODGE Ram 3500. I think the A/C drain is not draining properly. My carpet on the passenger side is always wet. I can not find the drain hose to try to unplug it. Where is this hose located????
Where are you located? Are you even running the AC this time of year?
The drain is located under the filter/dryer on the passenger side. It's a real pain to see, from up top. If this isn't your source of moisture, it will likely be your third brake light. Yes, I know what you're thinking. For some reason, when the third brake light leaks the water goes to the passenger side floorboard. Just the way the cab was designed.
This pic was taken from the bottom of my 99, with the top of the pic being toward the rear of the truck. Teh white/silver part at the top is the firewall.
Chris
Chris
Still need AC there? Man, I figured that far North you'd seldom need AC this time of year. Never been there this time of year though, so I guess I have no idea what I'm talking about.
Chris
Chris
westport
05-17-2010 06:57 PM
