How to hook up Edge EZ
The box says 5 minute easy installation, but I don't have any instructions with it, and I can't see where the wires are supposed to go. Can anybody tell me?
you should be able to download off their website but there is a map sensor hook up at the back of the block on the drivers side and another sensor right under the fuel filter inside a tape wrapped wiring harness.
Here is a link for the install.
http://www.edgeproducts.com/product_...manual-153.pdf
It took me some time to find the data link but it was under the fuel filter for my '02.
Here is what the manual says for your rig.
98.5-99 the triangle shaped connector is located on the drivers side of the engine in the wiring harness near the power steering pump
Good luck and have fun.
Thanks guys. I found what I think is the data link connector, but I haven't been able to get the connector on the edge to go down over it. I thought this edge came off the same model as mine. I'll look at is some more in the morning.
Turns out there was a part on the data link connector that had to come off, then the piece on the edge went right on. Got it hooked up, test drove it, and I can tell you now, I'm gonna like it! Can't wait to get my valve body in so I can do a few other things.
Glad everything went well with the 5 minute install, been there done that.
Rollie47
31
04-05-2009 09:21 PM
Co_Jacob
08-24-2007 01:09 AM
sheepboy10
04-11-2006 09:04 PM
Dodgezilla
03-12-2003 01:50 PM
