Houston, we have a tranny problem
Guest
Posts: n/a
47re with a DTT TC, BD Valvebody, BM shift kit, Amsoil fluid
Last worked on at 241,000 miles.
Problem: no lock up except with Torq-loc manual switch
Crusing a 70 mph at 1850 rpm is normal
today truck was runnning around 2150 rpm
I flipped on the Torq-loc switch and rpm dropped back into normal operating range.
Truck will not lock up in 3rd gear like normal unless switch is turned on.
Everthing else is normal - shifting, no slippage etc...
What do you think?
What do you think?
BBD, I'm just trying to think logically here, as I'm not any kind of transmission mechanic. If you had lost line pressure, or a solenoid, I wouldn't think that you could achieve any kind of lock-up. Because you can "manually" lock up the TC with the switch, I would think that the problem is either electrical, or electronic.
DeWain
DeWain
Since you can lock it with a manual switch, the problem is not in the trans.
I could be a connection/APPS/computer/ or brake switch.
I would start at your manual switch and check connections.
Guest
Posts: n/a
I dissconnected the TL switch and wiggled the brake switch and it worked like normal. I reconnected the TL switch and it still worked like normal. If it does it again I will have to go through the process of elimination . Everthing was fine until I stopped for coffee this mornin, but all seems to be good.
I dont have a load for in th emorning so she is going in for a check up anyway.
thanks alot guys
joe
thanks alot guys
joe
Rednecktastic
11-10-2010 09:49 PM
Gene007
Competition / Pulls / OffRoad
04-16-2006 08:38 AM
