Help!!! Engine Keeps Shutting Down
If you find that the lift pump is the issue,Genos carries a direct replacement for the cannister mounted pump that is cost effective. I have attached the link. This would be the easiest to install as it is a one for one replacement.
http://www.genosgarage.com/prodinfo....UMP_FPD4089602
Just changed the transfer pump but still get codes: P0628 & P0633.
Took it for a test drive without problems. Do you have to perform a reset or is there still trouble? Somewhere I saw a list of codes but can't find them now, anyone have the link to the page with the error codes?
Thank you!
Thank you!
Here is the link to the codes:
http://wiki.dieseltruckresource.com/wiki/Computer_codes
You could take the truck to a local parts store (AutoZone) and have the codes cleared with one of their code readers.
Thank you!
Thank you!
Thank you.
Cleared the P0628 at O'Reilly's, but the P0633 didn't show on their scan tool.
Anyone know what "P0633 SKIM Secret Key Not Entered" means?
ngrov
03-07-2009 08:13 AM
Pull Dog
04-08-2008 03:45 PM
