HELP!!! Death wobble i think and no one can fix it?????
Old 04-11-2009 | 08:30 AM
Wicked500R's Avatar
I can go double check. But I think the lengths of the factory control arms are 17.5" upper and 18.5" lower. I had a Nasty case of DW and I just installed the Top Gun arms on my truck yesterday. I got the stockers laying on my garage floor. I got the extended ones because I was already jacked up 3" in the front. I will say this.. 3" lift requires a new track bar and longer arms for the suspension geometry to be somewhat correct. With the factory track bar, the front axle ends up about 1 1/2" off center. This binds the control arms and doesn't allow the suspension to move the way it should. I'll post again after I have the definite lengths.
Old 04-11-2009 | 11:32 AM
Wicked500R's Avatar
Correction, uppers are 17.25" and lowers are 18.5"
Old 04-13-2009 | 03:46 PM
isissound's Avatar
I will go check mine thank you very much on the length I got off the phone with Don Thuren and he said that any truck can run with any amount of caster if IF properly set up for it he said that if I get his steering shock relocator kit and a good fox shock that it will totally cure my issue and then if I replace the control arms with what I need (which is still in question with the length I need) I will be all set so that's what I am going to do
Old 04-13-2009 | 04:14 PM
Wicked500R's Avatar
Here it is with the 99' T bar steering conversion.. I just installed it. You'll have to weld the tabs on the passenger side to mount it.
Old 04-17-2009 | 12:21 PM
wa.alldiesel's Avatar
you might need different shocks? Sometimes new things dont work properly. I went through two sets of shocks and still had the death wobble. I then put a set of good hd shocks on and that solved the problem, this was without all the steering mods. Just an idea.
Old 04-23-2009 | 07:12 PM
TOM R's Avatar
whats the point of adding that steering shock kit, mine has a factory one?
Old 04-23-2009 | 07:18 PM
Wicked500R's Avatar
I changed my steering linkage design and could not use the factory anymore so I put the best on it. The factory shocks are weak anyways...
Old 04-24-2009 | 01:10 AM
Hutch's Avatar
Here's a Jeep FAQ on Death Wobble.This may help:
Death wobble and steering wobbles in general are one of the most common problems after lifting your Jeep. I've been dealing with large and small steering wobbles off and on since I first lifted my TJ. It's an ongoing process as things wear. I have ORO's U-Turn steering system, RE 4.5 superflex, and 33x12.5 Goodyear MT/R's and I don't run a steering stab as it can mask problems. This is also my daily driver with a 25 mile (one way) commute that's mostly expressway driving, plus all the wheeling I can do on the weekends. The wobbles in my case are small things that I catch right away and fix before they affect vehicle control. Since I don't know what configuration you have on there, here's some general things to check:
***Remember, once you lift your Jeep, the factory specs will not necessarily work for your situation. Get underneath, get your hands dirty, and learn about your Jeep, in the case of steering, you and your family's life may depend on it!***
***Accept this fact...Death wobble will not be cured by a steering stabilizer. This may mask the symptoms for a while, they will return, potentially more dangerous than before as the worn components are now even weaker!***
1- Trackbar axle bolt TIGHT, hole still round, correct size bolt, bushings/joints in good shape.
2- Tires balanced? Super Swampers are notorious for being way out of balance. I use Centramatic dynamic wheel balancers to keep mine balanced.
3- Upper adjustable control arms to set correct castor. A good self check can be performed by placing an angle finder on the flat plate next to the shock just behind the axle tube. (Check each side.) If it's about 3 degrees below 0, you should be OK, less than that and you will likely have some trouble. Alternately you can use a socket on top of the upper ball joint with the angle finder and get your castor angle that way. In my case, one full turn of the upper arm equals one degree, YMMV. Don't forget to check the angle on the front driveshaft. DS and castor are a compromise to ensure safe vehicle handling with good U joint life, you may not be able to get either exactly correct, shoot for what works best for both.
4- TRE's in good shape, you may even have to disconnect the joints and move them by hand to verify smooth operation. Remember, easiest way to remove TRE's is to hit the surrounding metal piece with a BFH to loosen, don't hit the threaded end or use a pickle fork unless you want to destroy the joint. Grease the joints every oil change, grease is cheap, joints are not.
5- Solid lower control arms to prevent unwanted movement and flex, if you still have the factory ones they could be the problem.
6- Control arm joints tight, my RE superflex joints can be disassembled, cleaned, lubed, rebuilt, and reassembled as required. Alternately I can just tighten them up with an inexpensive tool. RE told me to rebuild after tightening 3 or 4 times.
7- Factory washers on the lower control arm to axle joint. My RE arms came with new washers, so I used 'em. They were slightly smaller in diameter and thickness them the factory, and didn't have the tapered edge to ensure correct axle alignment. Once I replaced them with the factory ones, it tightened things up nicely.
8- Check the joints in the steering wheel shaft itself, two under the hood and one under the dash. I had one wear and loosen up, and it took forever to find it. Felt like problems elsewhere in the steering system because it allows play between steering wheel and the rest of the steering system. I ended up replacing my intermediate steering shaft and was good to go.
9- Wheel bearings (hubs) in good shape? Cheapest I found for my wifes TJ was about $150 at Autozone, made by Timkin, highly respected bearing company. Everybody else wanted around $200. Don't do what the previous owner (idiot!) did to hers, he only tightened the axle nut to hand tight instead of 175 ft/lbs.
10- How about your ball joints? Same goes there, a good way to check is to jack the tire off the ground and see if there's any top/bottom play.
11- Ensure upper and lower shock bushings are in good shape, I had one get cut by a sharp edge on the upper mount, allowed some unwanted axle movement before any dampening occured.
Basically do an inspection of every part from the steering wheel to the tire. Verify each fastener fits correctly in the holes provided with no slop. Each time you find a component worn, or loose, and you tighten or correct the problem, your alignment may be off again. Get a factory service manual or Chilton's to ensure correct torque specs. Near the end of ORO's U-turn install instructions, they give a good step by step procedure for doing a self alignment that you can follow. Basically you use two 4' long 1"x1" aluminum angle pieces (Got mine at Lowes for about $5 each IIRC) held to the wheel with bungies, and two tape measures to check the difference. I do this about once a quarter anyway just to check. Make it part of your routine maintenance as it only takes about 20 minutes.
HTH,
Mark
_http://www.rubiconownersforum.com/phpbb3/viewtopic.php?f=38&t=29388
725Gus
03-06-2014 09:49 AM
Trooperthorn
11-30-2010 12:06 AM
Jezzhuntin
04-11-2007 04:52 PM
Fat Asp
12-11-2006 12:35 PM
YFZPILOT
02-24-2006 08:56 PM
Quick Reply: HELP!!! Death wobble i think and no one can fix it?????
