HELP!!! Death wobble i think and no one can fix it?????
Old 04-08-2009 | 01:28 PM
isissound's Avatar
hey guys about three months back I posted here because I hit a curb and folded my two lower control arms in half so some one here offered up a set of ranchos that they never got around to putting in I put those in now I have a scary case of death wobble when hit bumps on my way in and out of work in Boston My local NTB did an alignment they maxed out my caster and could only get it to 1.9 what do I need to do I need my truck
Old 04-08-2009 | 02:30 PM
elirandolph's Avatar
Call Don Thuren, I hear he can cure any case of DW. Search thuren fabrication for his number.
Old 04-08-2009 | 03:38 PM
isissound's Avatar
yea he hasent gotten back to me yet i left a message but in the mean time does any one know the length of the stock control arms ???
Old 04-08-2009 | 03:41 PM
Foxborough's Avatar
The death wobble could be from a lot of places or an accululation of worn parts. The simplest would be to check the tires. If you could borrow a spare from someone and use your spare on the front and see if DW happpens again. The bigger tires will loose their side wall streingth after a while or the accident you had could have damaged one or both of the tire sidewalls. Just my thoughts.
Old 04-08-2009 | 03:45 PM
isissound's Avatar
i will swap rear tires to front and see if this helps but other than that all front end componants are brand new
Old 04-08-2009 | 04:54 PM
patdaly's Avatar
Get more Caster.
I think mine was right at 3.7 degrees when we did mine.
Old 04-08-2009 | 05:11 PM
isissound's Avatar
yea i swaped tires out didnt help at all does any one know what the length of the stock lower control arms are i want to make sure that mine arent shorter than stock for some odd reason
Old 04-08-2009 | 06:58 PM
isissound's Avatar
allright so I was on the phone with top gun customz I am going to get the 3" lift kit from them with new control arms but I am going to go over the control arm length tomorrow with the fabricator when he comes in in the morning
Old 04-08-2009 | 07:09 PM
CamperAndy's Avatar
Not too may people put lift kits on to cure death wobble. Let us know how that works out for you.
Old 04-09-2009 | 06:36 AM
isissound's Avatar
the only reason i am looking at the lift kit option is so that i can get control arms that allow me to get enough caster to cure the death wobble does that make sence????
Old 04-09-2009 | 09:45 AM
CamperAndy's Avatar
Maybe to some degree but you said it started after you crashed and rebuilt the front end. Something else is still wrong and over adjusting the alignment is a bandaid more then a fix.
Old 04-09-2009 | 05:21 PM
patdaly's Avatar
I think what CamperAndy is saying is are you SURE the lower arms you put on were for a stock lift truck?
If they happened to be for a lifted truck, and thus longer, it would be hard to get enough Camber with a set of regular length uppers.
Another possible scenario is that the upper mounts moved somewhat.
One thing is for sure, they never should have let you out of the shop with that little of Caster.
Old 04-10-2009 | 07:09 AM
isissound's Avatar
the control arms that i put in are supposubly stock length and everything else in my front end checks out and it sure doesent look like any of the mounts are bent or have mooved i did replace both upper and lowers so im stumped
Old 04-10-2009 | 08:56 AM
John Faughn's Avatar
You have a combination of issues , a badly engineered ft. end , that is almost over weight , stock .
Then you had an accident , lots of unknown possibilities ?
It would appear that you are making some assumptions , the length of the arms [ no answers yet ] and that " it doesent look like any of the mounts are bent or have moved " .
If you have a problem , it could be almost anything , till you find the cause , never assume , test & verify .
It sounds like you did not have the problem before the accident ?
So the problem was added to the truck ?
There are a lot of mods to the front end on these trucks , but it would be best to solve the problem 1st then do the mods .
There are also some alternate alignment spec.s floating around for these trucks , but I have not done yet , because I am still working on upgrading my truck .
I had a so called death wobble that started with no changes to truck , freeway speeds , going around a left curve in road , I changed the frt. shocks and it is mostly gone , but still unstable .
Old 04-10-2009 | 11:06 AM
kawi600's Avatar
I had death wobble too. Solved by thuren trackbar, DSS and lukes links on all the steering linkage points and a good double steering damper.
Sounds like those control arms are not allowing full caster adjustment with your setup. The lift kit will help if it comes with control arms.
There is a pair of thuren prototypes like I have in the for sale section someplace. I highly recommend them. Theyre good from 3-5" lift.
Also highly recommend the thuren trackbar. 0-3" lift or 3-5" lift with relocation bracket.
Look me up if you need help with any of this stuff im local
Quick Reply: HELP!!! Death wobble i think and no one can fix it?????
