Help....Changing Springs
I cant get the ### lower control arm down. Is there a trick to this?
I removed the top of the sway bar bolt, the upper and lower shock bolt
and another bolt at the end of the upper control arm that had a pin through the middle. Any ideas on why it wont lower?
You can do that without ruining the rubber boot by striking the side of spindle with a large hammer. The white circular reflection below the numbers in your picture should work as an aiming spot.
this is what I did along with two extra jacks to push each one of the 'legs' on the control arm.
Thanks to everyone that helped
nottanuff03
09-22-2008 07:11 PM
highrpms
07-08-2008 03:05 PM
