help with airdog 150
i have my return and the pressure line backwards to the pics below
my truck ideals fine revs fine but put it in gear and give it some pedal and it runs out of fuel, type of feel
they also sent me the wrong wireing harness so i'm not sure what it is
do the ad 100 and ad150 route the same
i borrowd these pics from another member thanks Hvytrkmech
thanks, tommy
thanks, tommy
Hi Cracker,
You should have gotten the wiring harness with the single wire relay lead and not the Deutsch connector that plugs directly to the OE ECM pump lead. If you did in fact get the wrong wiring harness, my appologies. Call PureFlow tomorrow morning and we will send you the correct harness. Or, you could simply cut the two pin Deutsch connector off, connect one of the remaining wires to the green ground wire visible at the relay and the remaining wire becomes the relay trigger wire.
I hope this helps!
Charlie
I hope this helps!
Charlie
Floridacracker
01-06-2010 11:35 AM
CrashCade
12-03-2008 07:58 AM
dodgediesel
26
11-02-2008 12:20 PM
Ramtuff06
08-21-2007 06:21 AM
