help 99 with no heat i'm freezing
it has no heat, zero heat. I have flushed the radiator every thing is good with that, heater hoses going in and out of heater core are the same warm temp. When you turn the **** for heat i cand hear and se the arn wirjubg ti open and close the bypass door but i can't see the door. If it is the door how hard is it to change and were can i get one
Do you smell antifreeze?
I would think no matter what the direction the heat was set on, you would have some heat coming into the cab.
Usually when the heater core goes out, antifreeze will either come under the dash, or up on the windsheild.
no antifreeze smell, how dan i see the blend door with out taking heater core out, i cand see the little electrice motor that moves the dorr and it moves back and forth when i turn the heat on and off but temp doesn't change
How much is the motor turning ? It should turn about a half of a revolution from full close to full open. Also, there is a adaptor/connector between the motor and the shaft of the blend door that is prone to crack or break.
luke03cr
01-03-2012 05:07 PM
SSminnow
32
05-03-2006 05:07 PM
