heater blows luke warm air?!
hey...ive never had a problem with the heat in this truck...once it gets up to workign temp it gets nice and toasty in the truck...last 2 days the truck just doesnt blow very hot air...its luke warm...it doesnt matter what i position it to..feet, window etc...all luke warm...??
partially stuck T-stat is my vote
maybe a plugged up heater core?? hows your coolant look.... Clean?
whats your temp gauge showing while all this is happening?
Mark
BTW did you ever get your brakes fixed?
Mark
temp gauge is perfect..like its always been....plugged up heater core? hmm...could be...where do i check for this?
but if your coolant is really nasty or if you pull the radiator cap and see deposits inside on the passage ways of your radiator it could easily be a heater core.
I just remembered
does your truck have the heater valve on one of the heater hoses? It should be on the passenger side with cable going to it to control how much coolant is allowed to go to the heater core. maybe the cable broke and it is not moving the heater control valve.
I would try looking at that if I was you you may be able to open it by hand to see if it work or not
so now my new vote is heater control valve
Mark
No heater valves on modern vehicles because they plug up too often.
Newer rigs use a blend door that directs cold, heater core or a blend of the two to the vents.
I would guess your blend door is stuck letting more cold air in than you want.
thanks for the suggestions guys...infidel where so i check the blend door?...behind my dash?
Deer716
02-17-2010 11:03 AM
tony597fitter
13
02-07-2007 05:01 PM
