Gov Spring install
Gov Spring install
I"m kinda confused on Piers instructions as far as measuring from the gov. stud to the adjusting nut. All I see in the hole is the stud and what appears to be two spring keepers? Where is this adjusting nut? How does the spring compress to remove the keepers?
Thanks
Rick
Thanks
Rick
It looks just like 2 regular valve keepers, but it's the nut. The nut is wavy on the other side to keep it in place.
http://www.flex.net/~triplem/new/govspring.htm
hope these pictures help!
Nevrenufhp, thanks that info is a lot better than the stuff I have. Man WHAT A DIFFERENCE! I guess that when the pump was replaced on the truck, the original owner never had the other springs swaped. This is one upgrade that is well worth the $$.
Thanks again
Rick
Thanks again
Rick
fishin fever
03-13-2006 07:46 PM
Diesel-Dan
01-07-2004 05:44 PM
