A gorilla put on my oil filter!
I am out changing the oil & filter for the first time on my truck. I have 3 different filter wrenches in my shop, but none fit because of all the stuff around them and they wont slide on without major disassembly. So I use a strap wrench. The filter is tight!! The strap wrench dents the filter but wont turn it. So I go to the old trick of driving a screw driver with about a 8" blade through the filter and try to turn it off. Still wont go. I go to a 14 " blade BIG screw driver, Still won't turn. Put a piece of pipe over the handle. I pull so hard that I tear the metal on the filter, and it still wont budge! (Yes I am turning it the correct direction). Any ideas on what to try next?
DTR's 'Go to Guy'
CAUTION!!!!!
Grab the filter all the way at the top by the crimped ring.
Use either the plier type or the band type but be careful to not touch the red wire terminal on the back of the alt!
yeah the one from the factory is put on dry I think, first time I did mine what a **** I tell ya. I removed air inlet tot he turbo for more room to work and finally got it.
I always pull my air intake off from the turbo when I change mine. Allows me to inspect the wheel at every oil change to see if I'm having problems. I feel bad for the guys that have twins
Same here when i first bought my truck the dodge dealership did all the fluids and i tell you what that filter was a ***** to get off ended up getting a pliers type wrench from auto store and was able to get it off. All you do is a quarter turn after it is snug whats the deal.
I finally got it off! I drove the longest pointed pry bar I could fit down in the area through a new hole, then took a stick of 3/4" round stock about 4 feet long and stuck one end in a gap down by the front suspension and levered the first pry bar sideways. Kind of a level on a lever. Even at that, it took a lot of force. I had to knock 3 more holes to get a fresh grip as it turned a bit. It didn't turn by hand until it turned about 1/2 turn. Only shorted the round stock against the battery + pole once....
I will bet that stupid filter was torqued to around 140 ft-lb! it appears they never lubed the seal when they put it on which might have been part of the problem. Incredible. I'd like to ring some grease monkey's neck.
Thanks for the help!
It was a good tip to take off the air intake boot.
I hit the battery, not the alternator terminal. Will that blow the same fuse? What doesn't work if the fuse is blown (everything seems to work OK)
After these engines are assembled, they are shot with a coat of some kind of clear coat, filters and everything and it really makes things a pain to work on the first time.
