getrag tailhousing has a hole in it
the bottom part of my tail housing has been worn through by the shaft behind it when i removed the tail housing tonight the race just fell out and the seal or whatever it is that fits in the tailhousing rearward of the race doesnt look good either could this be a major prob or could a new bearing&race cure this prob. im going to have the tailhousing welded tomorrow
never looked at a 2x4, but either way, there should be some shims between the tailhousing and the race---if the tranny was still working good, don't lose those shims 'cause they're select fit to set up bearing preload inside the tranny. Should be the same deal for the countershaft on the bottom. Again, this is if the setup for bearing preload on a 2wd is similar to 4wd. The race isn't 'really' a press fit. I wouldn't be too alarmed that it fell out of the case. If you can get the tailshaft fixed, I'd say put the shims and race back how you found them and run it....these things are expensive to build, don't ask me how I know:< Kind of a weird setup and hard to explain...hope I didn't confuse things more. Maybe some more coffee.
greg
greg
Thanks G16 I havent lost the shims but im wondering why the shaft is wearing a hole in the housing could i cut the shaft back 1/8 or would that throw it out of balance
Originally posted by 1st gen Hobie
Whats the race?
Whats the race?
Sleigher
03-19-2013 08:13 PM
Dave88LX
09-13-2005 10:45 AM
driverswanted
07-08-2004 10:22 PM
