Gasoline and Diesel?
Old 01-19-2005, 09:37 AM
scottsjeeprolet's Avatar
Someone here at work put 1 gallon of gas in to about 26 gallons of diesel. is this going to be a problem?
What should i do?
thanks
scotte
Old 01-19-2005, 09:48 AM
Commatoze's Avatar
If it was REALLY just one gallon of gasoline, and there was REALLY 26 gallons of diesel fuel, I'd say you're ok if you top if off with diesel, and add a generous amount of lubricity additive. BUT!, take my amateur opinion for what it's worth.
Old 01-19-2005, 09:55 AM
winkle's Avatar
Dido what Commatoze said you'll be fine.
Old 01-19-2005, 11:07 AM
John Faughn's Avatar
The old truckers used to put 10%gas in for winter mix, but back then there was a lot of sulfur in the fuel so now you also need to add a lube , diesel is a oil , gas is a solvent.
94 Dodge cummins 2500 A.t. 4x4 straight pipe, K&N , the rest I do not know yet ,got it through add on this site.
Old 01-19-2005, 01:47 PM
SBishop's Avatar
Add a quart of ND 30W oil in the tank and forget about it.
Old 01-19-2005, 03:18 PM
DZLPWR's Avatar
yep, just add a quart or two of oil and it will be fine.
Old 01-20-2005, 04:15 AM
jrs_dodge_diesel's Avatar
Just in case you don't know ND stands for non detergent. Very important if you decide to put in a quart or two.
Old 01-20-2005, 01:42 PM
Thanks
Hey thanks for all the advice.
scotte
Old 02-05-2005, 01:53 PM
mandcgregory's Avatar
I've appreciated the info, as I just added 1 1/2 gals of gas by mistake. Going to get a qt of ND!!
Thanks,
MG
Old 02-13-2005, 10:15 AM
Vulcan's Avatar
Auto Zone carries the ND 30. I've had trouble finding it around here.
Old 02-13-2005, 11:26 AM
infidel's Avatar
A lot of places keep the ND behind the counter so people don't accidently pick it up and put it in their engine. You have to ask for it. The ND Napa sells is clear.
Old 02-13-2005, 04:56 PM
large_marge's Avatar
actually, gasoline is also an oil, and diesel is also a solvent.
Old 02-13-2005, 06:43 PM
infidel's Avatar
and sulfur doesn't contribute to the lube properties of diesel at all.
Old 02-13-2005, 07:46 PM
phox_mulder's Avatar
The process to remove the sulphur robs the Diesel of it's lubricating properties.
phox
Old 02-13-2005, 09:16 PM
i'll take your word for it
Quick Reply: Gasoline and Diesel?
