Front Sway Bar Bushing Removal
'99, 2500, 4x4, HD, front sway bar.
I have managed to get the top nut and bushing off, but the lower is a booger. The link is "L" shaped, with the bottom turning 90* into a bracket that's welded to the frame. There is a smooth space before the threads that goes into the bracket. Do you get it out of the welded bracket by beating the tar out of it? Or, do you need a press to get the old one out and the new one in?
(1) Raise and support the vehicle.
(2) Hold the stabilizer link shafts with a wrench
and remove the link nuts at the stabilizer bar.
(3) Remove the retainers and grommets from the
stabilizer bar links.
(4) Remove the stabilizer bar link nuts from the
axle brackets.
(5) Remove the links from the axle brackets with
Puller C-3894-A (Fig. 18).
(6) Remove the stabilizer bar clamps from the
frame rails and remove the stabilizer bar.
Is this what you needed
Hope it helps
axle brackets.
Hope it helps
Factory service manula for a 2001 basicaly same info for yours its just a stardard puller from the looks of the pic.
here is the link to it.
https://www.dieseltruckresource.com/...89&postcount=2
Thanks to Mopar1973man for the link
bigragu
02-22-2010 10:51 PM
Tiara3100
11-13-2007 11:20 AM
Robert373
04-03-2007 12:20 PM
