Front Rotor Removal 4X4 2500 HELP
Re:Front Rotor Removal 4X4 2500 HELP
Loosen driveshaft nut at wheel, remove brake caliper, loosen 4 bolts from the inside of the steering knuckle, pull out brake disk and wheel baring assembly. <br>Drive wheelbolts through disk and out of bearing housing.<br><br>pics and explanations at http://www.geocities.com/palmerlives...ubService.html<br><br><br>HTH<br><br>AlpineRAM
swhite832
01-30-2007 11:13 PM
