front end problems
front end problems
I have a 1998 2500 RAM diesel 4X4 I bought new. Around 2000, after I bought a Lance 1010 overhead camper, I started having problems. I was assured by eveyone (dealers) that my truck could handle the camper I bought. However, shortly thereafter, I had to have a new steering gearbox(under warrantee) replaced. I then went in to have my tires rotated at a tire shop and they found a "SPACER" on the right wheel, and had me sign a waiver for them to work on the wheels. The dealer said that was a manufacturers solution to a pulling problem and was perfectly safe. Then a few months later, a new traction bar. A year later new front end, the 2 stabilizer forks(sorry I can not recall what they are called, they have to do with the alignment) were replaced. Then in 2003 I had a major brake job done. new rotors etc. 60 days later they had to replace brakes again.. I have just put a new stabilizer bar in again. I then asked the Dealer if they would just fix the front end permenately. Here's the response, " no, you just have a bad truck, there's nothing we can do. We will sell a new truck but we will not take that one in trade."
I may not be a mechanic but they should have gave me some indication that that was a major problem during the warrantee. Befiore you make fun of me, this truck was only used for recreation, so there was no indication that it was a permenant problem to me. I tow a lot so I thought it was just bad luck instances. After what the dealer told me and going back over my records, I can NOW see a trend. The problem is that the truck pulls to the right when braking and the steerig feels like it's drifting when towing. I have seen an attorney and he has advised me. But, what I want to know is this a fixable problem with the truck(permenantly) or what? HELP!
As long as the frame is straight, I would say yes, it is a fixable problem. A guy would have to go through a pile of $, but it is fixable.
That dealer is brutal, what happend to customer satisfaction? Sounds like the dealer knows its a lemon from the day it rolled off the line and wants to wash their hands of it. I would bypass the local dealer and try a DC head office. Using spacers? I find that odd.
Sorry to hear about your problems. I think anything can be fixed, but without knowing the exact problems it is hard to tell if it would be worth it money wise. I would think in Pheonix you would be able to find a decent front end mechanic, any other member out there have suggestions on where to take the truck in pheonix area. Sometimes a specialty shop is better than the the dealer who has to work on many different cars/trucks and many different problems.
wow. I feel for you brother. I cant really tell you what to do, but if it was me I would look into these products.
dt pro fab trac-bar
Darrin's Steering Stabalizer
These 2 would probly help you tremendously. I would also consider replacing all bushings with polyurethane bushings. You can get them from here
good luck!!!
dt pro fab trac-bar
good luck!!!
Re: front end problems
02Diesel
11-09-2006 07:21 AM
seralan
16
02-25-2006 03:16 PM
Gordonville
04-18-2005 09:45 AM
royta
07-13-2004 06:54 PM
