Front driveshaft u-joints
I need to replace the u-joints in the front drive shaft.
Can I pull the front driveshaft and drive? What are the pins that appear to be holding the front u-joint in I got clips with the the replacement?
Do I unbolt the shaft at the hex heads (front)and the 5/8 in bolts (rear)?
Any tips on pressing out the joints at the cardon?
2003 2500
2003 2500
Not shure what the pins are your talking about, foggy memory. You can drive with out it on there, i do it alot and never had a problem. As for tips put it in a vise and use a small ball joint press that looks like a c clap with different adapters and you wind it in and out with an air gun.
The pins are what is called glue in u-joints , a good rap with a hammer will crack/break the plastic , then change as normal .
driving without the ft shaft is not a problem .
2003 2500
2003 2500
If you need to replace he u-joints in the cardon joint, you probably need a new ball in the center of the cardon. It's just cheap insurance while you have it apart. I believe the centering ball kit is only about $30 or so.
A bonus of changing out the centering ball is ou dont have to worry about it when you take it all apart. Blow it apart and give everything a good cleaning and put it back together fresh as new.
Jeff
Jeff
This was all great advise. I did blow the ball apart when removing the old u-joints I am going to replace it too.
Heating the epoxy would have been worked better than the press I used.
my front u-joing blew on me on the highway. thankfully the driveshaft didn't drop. scared the living you know what out of me though.
cmp truck
0
06-09-2015 04:40 PM
tim2251
04-10-2010 10:19 AM
