engine won't turn off HELP
Old 03-20-2006 | 12:53 PM
lonepalms's Avatar
engine won't turn off - PLEASE HELP
Yesterday morning I started my 97 3500 4x4 automatic and it was making a noise (not loud) that I couldn't make out. Killed the truck and re-started, no more noise. Later in the day I started it and it made the same noise, tried to kill the engine, nothing would happen, kept running, could not shift into gears though, shifter would not move. After about a minute I was able to turn the engine off. Please help as I don't have an idea what this could be. Could it possibly be connected with the serpentine belt?
Old 03-20-2006 | 01:17 PM
Mcmopar's Avatar
I was going to say the shut down solonoid was sticking. The gear shift thing?? No idea.
Old 03-20-2006 | 02:01 PM
darkvader's Avatar
may have been starter hanging up. strange sound may have been starter not diengaging. does not the shift colume lock when key is offI don't know).
Clark
Old 03-20-2006 | 02:25 PM
Geico266's Avatar
Welcome to DTR
First, take a min & fill out your signature.
The strange noise could have been your starter plunger sticking to the starter contacts. Both are easily replaced in an hour.
http://www.fostertruck.com/dodge/default.htm
They have fuel solinoids also.
Nothing to do with the serp. belt that I can think of.
Old 03-20-2006 | 02:34 PM
darkvader's Avatar
he said 97 3500 auto 4x4
Old 03-20-2006 | 03:20 PM
lonepalms's Avatar
Thanks for the help. If the starter is hanging up, does this make the engine continue to run when the key is turned off? To clarify about the gear thing, When it does this thing it does I can't take the truck out of park, it is like the truck is not started, if that makes sense.
Old 03-20-2006 | 04:32 PM
RCW's Avatar
RCW
Yes, depending on what you did when it kept running. Generally what happens is the old starter relay carbonizes and sticks enough to put enough power through to the fuel shutdown solenoid to keep the engine running. The key will be shut off, the gear selector is then locked, and the steering wheel locked, but it just keeps running...
It is also possible for the ignition switch to fail and create a situation where the engine will not shut down, but that is almost always preceeded by a hard to start situation where the ignition switch is failing to make complete contact and you grind away with nothing happening.
Old 03-20-2006 | 06:52 PM
infidel's Avatar
Definitely starter contacts, $35 and and an hour to fix it.
This explains what's going on http://www.fostertruck.com/dodge/starter%20faq.htm
Fix it ASAP or you will burn up the shutdown solenoid and possibly some wiring too, then the bill goes up to $200 plus.
Bradleyras
10-23-2014 08:32 AM
stealman1
11-09-2007 11:07 AM
IntakeRacing
10-20-2005 11:30 AM
RottnRam
09-22-2005 04:38 PM
Quick Reply: engine won't turn off HELP
