engine sounds like it runs on 1 cylinder
Well after 2 push rods got bent, installed new ones and redid the valves. I figured nothing else would have happened in the motor. Well it turns out, that one the starter struggles to turn the motor over. 2 when the motor tries to fire and does it runs, and sounds like its only on one cylinder. All the valve train is moving. What am i looking at? Maybe i did the valves completely wrong? Any help would be greatly appretiated.
set the lash in them. could i have done it wrong....to add to it, currently on cylinder 5 i can wiggle the intake and exhaust rocker arms, the rest of the valva train is tight as can be.
yes, what i dont get is why it is so hard for the motor to turn over, the batteries are charged. Broken Cam? Broken Crake? Piston?
If your lash is incorrectly set you may not be opening the valves and therefore the engine is effectively acting like it has a Jake brake installed. If you didn't remove the injectors, is there a chance you lost prime in the fuel system. If this is not an option try readjusting the valves making sure you follow the procedure exactly. Hopefully you haven't bent any of them.
ok thanks for the input, i will reset lash tomorrow morning and hope for the best. Does the possibility exist that a piston or crank is busted?
That we are unsure of, originally started with head studs, installed them did some heat cycles, then retorqued them and we pulled the valve train off. Went to restart and it was popping the noise when the air comes back through the intake. Took out the two bent rods installed new ones, and reset lash and now it doesnt run worth a .02
60valves
04-16-2015 07:32 AM
Chris Taylor
05-17-2011 09:43 PM
buickturbot
03-05-2007 10:55 PM
steveb
17
01-24-2004 10:15 PM
