Engine Fault Codes
Engine Fault Codes
Sorry, I know this has been posted many times before. But, today I have just wasted about an hour looking for it. Last night I looked in my Dodge service manual for about an hour (That is the hardest manual in the world to find stuff) Can anyone just off the top tell me where to find the list of engine fault codes for the pre 94 trucks. I did not see it in the Tech Facts at this sight.
thanks
thanks
Re:Engine Fault Codes
Code 24:<br><br>DRB Display: Throttle Position Sensor Voltage High OR Throttle Position Sensor Voltage Low<br><br> Throttle position sensor input above/below minimum/maximum acceptable voltage. <br><br>Sounds like the TPS is either set too high or is pooched. Hope this helps you out.<br><br>J-eh<br>
jmlcolorado
12-07-2009 02:31 PM
cmckinney
08-06-2003 04:28 PM
