edge juice with attitude problems
I bought the Edge Juice with Attitude today and installed the system per the instructions. When I got done and went through the start up sequence I had some very weird stuff happen. The check engine light is lit, the odometer flashes several times and then gave me a "NO Bus" message. in addition The attitude asks me to aggree to the terms of use every time I turn the ignition on. Any help would be greatly appreciated. feel free to call me at 303-378-3846. I am in the Denver area.
BTW This is on a 99 w/ automatic tranny.
It started But.....
I got the truck started and the attitude is working normally. Now for the new problems. The gauge cluster is going haywire. All the needles are jumping. The odometer is flashing and the air bag light is falshing. Now what. Is there some sort of reset procedure that I can perform?
I'd look to see if you accidently unplugged something under the dash/hood while you were installing it..mine worked fine,1350f on the pyro is tooo hot to pull a heavy trailer with (long hard pull)
Ask me how I know...
Got it started.
I got the truck started and am driving it. It runs fine. The Attitude seems to work fine. However, The gauge cluster is acting very funny. All the gauges are constantly moving and the seatbelt light flashes constantly. In addition the odometer is flashing at me. I disconnected the new chip and the problem with the gauge cluster did not change. I have unplugged the fuse and the gauges are dead now. I have not had a chance to move any wires around yet. But if anyone has any thoughts, I would really appreciate it
sounds like you knocked something loose some where, you can try and unhooking your batteries, for 30 minutes and see if that does anything. It will ask you to agree with the terms five times and then i wont ask you again.
sound almost like when i did my VP44 and forgot to plug in the main harness connector at the back drivers side of the head..... everything was acting funny, got the ccd message as well..... might want to check that out.
I got it figured out
One of the guys that wanted to help pulled fuse number 17( gauge cluster A). I checked all the fuses and noticed it was missing Before I took it to the dealer that sold me the Juice. Problem solved. Imagine that. What a great box.
13jeeps
12-16-2012 10:00 AM
razor6
22
01-20-2006 03:43 PM
