Driver's door won't unlock!!!
...All other doors will unlock but the driver's door will not unlock using the remote or the key. There is no sound and the key won't turn.
I have removed the lock/latch unit but cannot get it to function. My 3/36 is expired as it happened at just under 41,000 miles so warranty is out.
Suggestions on where to get a replacement other than dealer hopefully.
TIA!!!
TIA!!!
BZZZZZZZ! incorrect answer. Guy has a DR body and needs a door latch assy. The power lock mech has binded up and is part of the latch. I would get a new one as the part has superceded a few times. You go to the "recycler" and you may end up with the same pos you have now.
Thanks for the replys. I started checking salvage and there wasn't much available in my area that I could find. So I did go to the dealer just to "price" it out. Turned out to be just under $50 with tax. I went ahead and ordered it.
mkelly9779
03-08-2009 05:57 PM
Floridacracker
13
01-20-2009 12:12 PM
Deer716
10-06-2008 12:43 PM
nomad65
08-20-2007 06:01 PM
Bowman
03-26-2004 07:25 PM
